Rear brake problems. SORTED!!!!!
Flipping lwb brakes wont work.
Tested everything.
Deleted bias valve
Swapped hoses over tried old rubber hose too
Swapped calipers over both okay
Bled with calipers up top
Fitted another master and servo ( cheers jordi)
Clamped off rear feed flexi hose from wing to chassis front brakes working fine good solid pedal
Blanked off one side of axle t piece . Drivers rear good solid pedal
Blank other side of t piece and Try with Rear passenger and it just lets pedal to the floor
So im left with the t peice or copper pipe being at fault which makes no sense.
will try again tomorrow. Im heading home
Tested everything.
Deleted bias valve
- Ladaman
- Suzuki Guru
Re: Ahhhhhhhhhhhhh!!!!!!!!
Sounds like a long frustrating day.
Good idea to go home. Hopefully you will see the obvious mistake straight away next time you look at it, and think what a ****.
Good luck.
Good luck.
- Edweird
You sure the servo is working? Duff connection, vacuum leak or something? Sounds like a dead servo to me at least.
- suzukisteve
- Suzuki Guru
Re: Rear brake problems. Loosing the will
as ladaman said andy, some times you jus gotta walk away and come back to it later to be able to see the problem. hope you get it sorted bud
pickle power!
Discs or drums on the rear?
Converted to discs.
Should have kept the flipping drums
andyrew wrote:Converted to discs.
My rear disc conversion went in the skip and I went back to drums.
- suzukisteve
- Suzuki Guru
how are you getting on with this andy? managed to sort it ok?
pickle power!
Andy... I have braided hoses across the rear axle a good t/pipeandyrew wrote:Flipping lwb brakes wont work.
Tested everything.
Deleted bias valve
will bring along with me also got the servo if u fancy swapping stuff around to eliminate the one fitted
He's on the second servo and master cylinder now.4x4rick wrote:Andy... I have braided hoses across the rear axle a good t/pipeandyrew wrote:Flipping lwb brakes wont work.
Tested everything.
Deleted bias valve
