Suzuki sj 410 from Cornwall PROJECT Never Ending Project
dazerede
Re: Suzuki sj 410 from Cornwall PROJECT Never Ending Project
Post by dazerede » Wed Sep 11, 2013 9:01 pm
Yep ok I will just bolt them on how they are
I.just can't wait.to fit them but I ain't got much.time on the evenings as I need it to get to work and college
4” calmini lift kit :)
dazerede
Post by dazerede » Sat Sep 14, 2013 8:01 pm
:argh: wheel bearing is gone in the rear axle :argh:
But I have fitted the new springs and tadah they are 1.5-2 iinches higher than.my old ones
suzukisteve
Post by suzukisteve » Sat Sep 14, 2013 8:33 pm
lookin good dude, where did you get em from?
rear bearings are easy to get hold of and not to bad to fir either :thumbup:
pickle power!
dazerede
Post by dazerede » Sat Sep 14, 2013 8:37 pm
Are all 410 bearings the same as I have a Spanish 410 rear axle on my zook
Got them of eBay http://www.ebay.co.uk/itm/SUZUKI-SJ410- ... 0850654254
The hardest bit is getting the shaft out I had a spare axle so I thought I would take that one out and that one was easy but the shaft in my zook is stuck in.there
suzukisteve
Post by suzukisteve » Sat Sep 14, 2013 8:57 pm
can you use a slide hammer of the like on it? might give it enuf force to get it to move mate.
you gonna do a ruf then?
pickle power!
dazerede
Post by dazerede » Sat Sep 14, 2013 9:09 pm
I plan to do ruf in a coupe of mounts but funds is getting a bitblow so can't for a while
I bolted a pice of angle metal on too 2 the Drum nuts and I put a car sissor jack in bertween the spring.and the angle metal and all it is doing is bending the meatal I gave up for the day about 2 hours ago but I.will have a better go tmoz
What do I need to get to do the rear wheel bearing
Wheel bearing
Spacer
Oil seal
suzukisteve
Post by suzukisteve » Sat Sep 14, 2013 9:34 pm
if you buy a bearing kit it should have everything you need in it. gimme a sec and ill find a part number
pickle power!
suzukisteve
Post by suzukisteve » Sat Sep 14, 2013 9:37 pm
here we go: adk88204 or brt973
should be able to get either from most factors
pickle power!
Post by Darrell » Sat Sep 14, 2013 10:27 pm
dazerede wrote:I plan to do ruf in a couple of mounts but funds is getting a bit low so can't for a while
I bolted a piece of angle metal on too 2 the Drum nuts and I put a car scissor jack in between the spring.and the angle metal and all it is doing is bending the meatal I gave up for the day about 2 hours ago but I.will have a better go tmoz
Wheel bearing
Spacer
Oil seal
A new retaining collar, often part of a kit!
Maybe a brake pipe spanner, unless your backplate has the section that comes out.
A ordinary spanner may do, but once the nut is rounded off its a pain.
A angle grinder.
Access to to press.
Rear wheel bearing diagram.jpg (365.94 KiB) Viewed 5887 times
dazerede
Post by dazerede » Sun Sep 15, 2013 10:59 am
Right I give up
I have tried it this way and no luck my other shaft came out piece of piss a while back using it this way I just don't understand Chears Darrel I might aswell buy 2 kits just incase my other bearing goes in my rear axle
