Front Suspension problem!
TomBod08
Re: Front Suspension problem!
Post by TomBod08 » Sun Sep 15, 2013 11:20 pm
Jordi wrote:Fronts should have a set of longer bolts with them.
Soak the fronts on your SJ with a good amout of WD40 over night as i always shear the bolt when i undo them.
Yeah will do, I tried to replace the drop arm yesterday and snapped 2 bolts :-( , not a happy man at the moment
One life. Live it....With a Suzuki
Post by Jordi » Sun Sep 15, 2013 11:22 pm
As the rear bump stop it a funny shaped box it might be quite hard to drill through it.
Post by Darrell » Sun Sep 15, 2013 11:24 pm
If these springs are longer and the spring pack bolt is in the centre does this mean the front axle has been moved forward ?????????
Looking at the rear spring pack it doesn't look like it would even compress, let alone reach the bump stops (how many leafs !!) :er:
Pics to show the calami kit along side MGP one.
TomBod08
Post by TomBod08 » Sun Sep 15, 2013 11:25 pm
Jordi wrote:As the rear bump stop it a funny shaped box it might be quite hard to drill through it.
Hmm it would be a bit awkward wouldn't it, I really need to find someone with a welder really :weld:
Post by Jordi » Sun Sep 15, 2013 11:26 pm
Darrell wrote:If these springs are longer and the spring pack bolt is in the centre does this mean the front axle has been moved forward ?????????
Think Dans ironmans are 5 leaf.
Post by Jordi » Sun Sep 15, 2013 11:28 pm
I'm not a million miles away if you get stuck. I think the current agreed rate is a crate a day, the preferred currency of cider of course.
TomBod08
Post by TomBod08 » Sun Sep 15, 2013 11:29 pm
Good point I never noticed that, it would of only moved it by about 1/2" thought wouldn't it?
I have taken a leaf out of each spring as well, I went on a mile trip with them all in and had to turn back as it was unbearable :lol:
TomBod08
Haha true, I'll have a think about it ;)
Post by Jordi » Sun Sep 15, 2013 11:32 pm
If theory the axle has not been moved forward. The springs are only longer to allow a greater curve. If you sat the spring side by side with a standard spring the bush centres should line up. The lift spring will just have a bigger curve.
It does mean under articulation as the spring flattens the axles will move further forward. This can be worked out by halfing the distance of the difference in length between the old spring and new spring.
Ladaman
Post by Ladaman » Sun Sep 15, 2013 11:37 pm
I'm only in Huddersfield. I can help if you want.
