Hi guys I'm new.
Ant161
Re: Hi guys I'm new.
Post by Ant161 » Wed Oct 30, 2013 7:24 pm
Ha I thought it would be easy too.
I've come to fit and the plug and bracket don't match,, any ideas please
Post by Darrell » Wed Oct 30, 2013 10:31 pm
What's your plan.
Get the correct alternator or make it fit/work..
Ant161
Post by Ant161 » Thu Oct 31, 2013 7:02 am
Would it be possible to change the plug??
Have you seen this plug before because I can't find one like it online.
Cheers ..
Post by Jordi » Thu Oct 31, 2013 7:10 am
Fairly sure that is the Japanese plug / alternator
Ant161
Post by Ant161 » Thu Oct 31, 2013 7:38 am
Where is best place to get the right one for me. I'm guessing I need a Spanish one.
suzukisteve
Post by suzukisteve » Thu Oct 31, 2013 8:13 am
id say pop down to your local motor factor. take that one with you so you can show em whats wrong with it
pickle power!
Post by ScottieJ » Thu Oct 31, 2013 9:10 am
I think I have a spare plug for that alternator ;) do you want it?
Post by twiss » Thu Oct 31, 2013 9:26 am
Or if you can't be bothered with the plug....
ring connectors on the ends of the white and yellow wires... then connected to terminal B in the pic... then spade connector on the white and red wire, connected to (i think) the right side pin (in the pic) of the alternator socket
if the dash battery light doesn't come on with the ignition, its a different pin :)
I prefer those alternators as I think it's the one with the internal cooling fan.... doesn't spray mud and water across your engine bay that way ;)
Ant161
Post by Ant161 » Thu Oct 31, 2013 9:40 am
Cheers guys. That plug would be great cheers
timwilks13
SCUK Website Padawan
Post by timwilks13 » Thu Oct 31, 2013 10:44 am
you could just put some spade terminals on the relevant wires and just push them onto the correct pin? there is a picture of that alternator wiring here if you need http://forum.suzukiclubuk.co.uk/vi ... =11&t=5383
