Post
by Jordi » Fri Nov 29, 2013 3:15 pm
dan_2k_uk wrote:Or possibly a body lift but they push the COG up too.
Not as much as SPOA though.
Longer shackles are required for lift springs. All depends how much lift the.springs give and how much longer than standard springs they are.
Post
by dan_2k_uk » Fri Nov 29, 2013 3:16 pm
Any lift that moves the axle away from the chassis would need shocks and brake lines extending or dropping.
more948
Post
by more948 » Fri Nov 29, 2013 3:18 pm
Ok new springs and shocks will be on the cards if i buy it tomorrow. SOrry to ask loads of questions but what is the biggest sizes tyre you can run without a Lift? and are they any good off road?
Post
by dan_2k_uk » Fri Nov 29, 2013 3:26 pm
I can't answer that I'm afraid but I'm sure someone will be along.
Don't worry about asking too many questions. Keeps us busy
- The Boss
Post
by ScottieJ » Fri Nov 29, 2013 4:11 pm
235/75r15 are the biggest you can fit with no lift, just need to do some trimming on the front bumper and bumper mount. Maybe some 30" at a push with more trimming and the bulkhead seam being flattened over.
Jordi it depends on the springs, most lift springs don't need to be ran with longer shackles, it's only the llama ones from what I've seen so far.
Post
by Jordi » Fri Nov 29, 2013 4:20 pm
ScottieJ wrote:235/75r15 are the biggest you can fit with no lift, just need to do some trimming on the front bumper and bumper mount. Maybe some 30" at a push with more trimming and the bulkhead seam being flattened over.
Im on llama springs Scottie without extended shackles. I'm probably ok as i extended the bump stops. All depends on the overall length of the spring when fully compressed.
Post
by twiss » Fri Nov 29, 2013 4:23 pm
Its just my particular springs haha
If I had a different bumper though the springs wouldn't hit on anything
- The Boss
Post
by ScottieJ » Fri Nov 29, 2013 4:32 pm
Yeah twiss does need to extend his bumpstops before he kills his springs from over flexing them
twiss wrote:Its just my particular springs haha
Instead they would invert and stay inverted
Post
by twiss » Fri Nov 29, 2013 4:35 pm
lol they still dont overflex, i have the shackle bashing into the bumper as a warning
lets call it an audible bump stop haha
when it goes clunk, the wheel can go up another 2" before the spring flattens
more948
Post
by more948 » Sun Dec 01, 2013 1:21 pm
Right guy i bought the sj, What do you think?
It looks like it might of had a little lift already?
It needs the front brakes sorting as one of them is binding but other than that all seems ok.
- IMG_4103.JPG (2.33 MiB) Viewed 4284 times
