Bonjour and can you help ??
Bonjour all Zookies !!
I bought Carlos (my SJ Santana) few years ago and had a great time.
But I need to prepare the MOT and went though all bits that can cause a failure.
I discovered that the left front wheel bearings had to be changed. Bouth some spares and when opened the caps discovered that the existing bearings had gone !!
The nut (Bolt) was not tight on anything because the thread on the other metal part had gone as well.
Has someone faced the same problem and can I either repair it or find a complete spare parts ?
Some pics may help to see what I'm trying to talk about !!!
Froggy
Froggy
- urbanzook
- Winching along now
Re: Bonjour and can you help ??
do you mean this bit?
will find the part an take a pic
- bit.jpg (19.53 KiB) Viewed 9128 times
- urbanzook
sorry forgot to say drinks on you
post a pic i wanna Carlos
found it!!! is this it?
- bit.jpg (61.61 KiB) Viewed 9127 times
Eh your a star Urbanzook !! This is the bit and of course the nut and washers that go on it. I think that the previous nut went loose and the bearing destroyed the thread.
Would you be happy to sell it to me or let me know how it's called so I can buy one ?
Of course the wine is on me !! Not french one though it pretty extortionate for the quality !!!
If you're happy to sell it I can send you a cheque or other.
Merci,
Froggy
Wil post Carlos pic tomorrow !!
Merci,
Froggy
seem to have problem with posting pics !!
How would you call that bit Urbanzook ?
By the way I like your camo zook !! and the US type custom dragster too !
If urbanzook hasn't got one then i have. PM me if urbanzook can't help you.
Scottie J
Scottie J
- urbanzook
sorry took so long to get back 2 ya.
see scottie as mine has the bearing collar welded on to it is a scrap part that iv not got rid off
NO Probs and thanks Urbanzook.
Will contact Scottie and hopefully should post pics of Carlos running in Salisbury plain ruts soon !!!
howdy and
if in doubt, FLAT OUT!
- urbanzook
froggy where are you, i guessed france as for the froggy name an the bonjour, but to the best off my knowledge Salisbury plains is in the uk.
