Forum
Bear3017
Re: Forum
Post by Bear3017 » Tue Mar 25, 2014 5:59 pm
Once again, Thanks so much, feel real welcome !! Hope to put a pic up soon and if anyone does have any info for me at any time brill. One question, when i start fumpa from cold - ok, when warm, have to lift bonnet, connect brown and yellow wire from coil to brown and yellow wire from loom, turn engine over until it tries but won't run, disconnect wire start her again - runs no probs ? :er:
Bear3017
Re: Forum
Post by Bear3017 » Sat Mar 29, 2014 9:24 am
HELPPPP ! Could anyone tell me what the brown and yellow wire going to the coil is for on my zuki santana ? Bugger won't start till i connect it and then dissconect it when she's warm ?? fine when she's cold tho ?? Please help me if you can, Ta
Re: Forum
Post by twiss » Sat Mar 29, 2014 5:53 pm
Try replacing your coil... those wires connect the coil to the distributor so one of them is probably at fault
Is it a 1.3 or a 1.0???
Also please don't post the same thing over and over in different places
Re: Forum
Post by twiss » Sat Mar 29, 2014 5:56 pm
How to check your ignition coil:
Bear3017
Re: Forum
Post by Bear3017 » Mon Mar 31, 2014 4:55 pm
Sorry Twiss, just learning about where to put what !! Will try what you say, looked all over to try and identify the brown and yellow wire but no joy ?? Oh, iv'e got the Zuki Santana, 1ltr
Bear3017
Re: Forum
Post by Bear3017 » Mon Mar 31, 2014 5:00 pm
Does anyone have a hard top for sale please ? Not worried about cracks/scratches etc as it's going to be cut about somewhat.
dominic
Re: Forum
Post by dominic » Mon Mar 31, 2014 8:47 pm
:welcome: bear
Nice one.
We will all try and help and give any advice.
As im not in you neck of the woods, I cant help on garages.
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
Bear3017
Re: Forum
Post by Bear3017 » Mon Apr 07, 2014 10:22 pm
Tried the coil :thumbdown: no joy. Twiss, could it be a fuel problem as it only happens when hot ?? vapourising in pipe ?? Any ideas :S
Re: Forum
Post by ScottieJ » Mon Apr 07, 2014 11:30 pm
This is how the coil should be wired up.
Can you post a photo of your wiring please?
Bear3017
Re: Forum
Post by Bear3017 » Wed Apr 09, 2014 5:06 pm
Will do asap. Seems to be a green wire to +, a lead going to nothing (brown and yellow) which, when she won't start i connect to the one coming from the loom and she will fire but not run, disconnect and off she goes ??
Seems to be tho, if i leave her to cool this also works and she's a little lumpy till i put my foot down so ... fuel ? going to give her a full check over this weekend
