Tramps Truck,
muddymesser
Re: Tramps Truck,
Post by muddymesser » Mon Feb 10, 2014 6:48 pm
nice :smokin:
Re: Tramps Truck,
Post by Tramp » Mon Mar 24, 2014 10:22 am
......ordered :thumbup:
Re: Tramps Truck,
Post by Tramp » Sat May 17, 2014 9:35 pm
I made a start fitting my bearing kit today, I had a few hours on it and got grease everywhere! I was chuffed to get the felt & rubber seal on without cutting it. Then I had to go to work, I did have one little issues though,
- My track rod end (well my ball joint), I was going to split the linkage so loosened the nut off the top unfortunately when it was far enough off I tapped it and the linkage started spitting, but now the entire track rod pivot spins when trying to undo the last threads on the nyloc nut, is there a bolt head under the rubber gator?
*edit* I gave the kingpin pivot a lick around with emery and it was fine, it slotted in easily like there was no problem!
Re: Tramps Truck,
Post by dan_2k_uk » Sun May 18, 2014 8:49 am
Can normally just push it back up a little so the taper locks a bit to undo it and then tap it back down
Re: Tramps Truck,
Post by Jordi » Sun May 18, 2014 11:29 am
Nice to see a bit more work being done. Can't wait to see this back on the road, always liked your truck for some reason bud.
Re: Tramps Truck,
Post by Tramp » Mon May 19, 2014 12:20 am
Thanks :doublethumbs: I always liked my truck too!
I've had a busy evening..........
Hopefully it will be dry by the morning so it can be refitted,
Re: Tramps Truck,
Post by Tramp » Tue May 20, 2014 3:49 pm
Drivers side almost done
And one of the best bits about this rebuild kit......
Shiney bits!
Re: Tramps Truck,
Post by Tramp » Sat May 31, 2014 5:46 pm
Another fun day, I fitted my new bearing assy and king pin bearings on the passenger side, I fitted new brake hoses too but suffered a small issue
What are your thoughts on this? Drill it out and retapp it? Or do I need a new caliper? The drivers side bleed nipple is just as reluctant to be removed!
Re: Tramps Truck,
Post by ScottieJ » Sat May 31, 2014 8:43 pm
Nice work! Will be awesome to see your Sk back on the road!
As for the nipple you could try a stud removal tool. http://www.ebay.co.uk/itm/110868152075
Re: Tramps Truck,
Post by Tramp » Sat May 31, 2014 9:57 pm
Thanks I'll I've give it a go but I'm not hopeful it seemed pretty stuck! I could also do with another swivel hub seal bolt I had a full set but one has managed to get lost! If anyone has a spare kicking about? Its very annoying, what are my options if I cannot get the thread out? Do I need to buy a set if new calipers?
