Weber pancake filter
Corrado vr6
Post by Corrado vr6 » Sun Jun 22, 2014 12:21 am
Hi there, I believe my sj413 1992 has a weber carb according from doing a search on here, I'm after to loose the standard air box as it won't fit in my project, so looking for a pancake filter, can anyone recommend a good one?
Cheers Greg
Re: Weber pancake filter
Post by Tramp » Sun Jun 22, 2014 8:02 am
People do use pancake filters but you loose a few options if you do. For example you can run a snorkle from your standard airbox, also Suzukis come with a hot air feed which takes air from around your exhaust manifold the plastic lever/ wing nut on the filter box lets you use this so you don't get carb icing in winter,
Corrado vr6
Post by Corrado vr6 » Sun Jun 22, 2014 10:03 am
Ah ok, I guess I'm going to have to weigh up my options
Post by twiss » Sun Jun 22, 2014 10:16 am
Personally mate I would do as tramp says... get one of the standard plenum chambers for the weber and hook it into the standard airbox like so:
Or to any other kind of airbox you can fit in there ;)
Corrado vr6
Post by Corrado vr6 » Tue Jun 24, 2014 11:57 pm
What model is the Suzuki weber carb eg DGV DGAS?
1992 1.3
Post by ROBBIE » Wed Jun 25, 2014 8:28 am
DGV
Post by Tramp » Wed Jun 25, 2014 8:34 am
Dgv 32/36
