hello all I have a Suzuki Samurai which was sold to me with a fake MOT and now it has failed a legit MOT on excessive corrosion so I need to remove the body to get to it but I don't have the facility to do that....any ideas ? based in Bedfordshire
mot centre have been reported to Vosa
cheers
welding
Re: welding
4 people can easily lift and sj body off the chassis.
Where exactly is the welding needed, i have done most of the hard parts just by raising the body 6" off the chassis and placing it on blocks of wood between the chassis and body.
Re: welding
I may be wrong but I believe corrosion is subject
To mot testers opinion.
So if they feel its safe its able to pass.
How bad is the rot and where?
Re: welding
that is a brilliant idea....thanksScottieJ wrote:4 people can easily lift and sj body off the chassis.
Re: welding
three points within 30 cm of the seatbelt anchors and the middle front body mount !andyrew wrote:I may be wrong but I believe corrosion is subject
Re: welding
I did this method and it worked very well...all the welding done ,,,now just need to sort the emissions for the MOT...then some fun with my ladradioman wrote:that is a brilliant idea....thanksScottieJ wrote:4 people can easily lift and sj body off the chassis.
thanks for the tip
