A question of stability
just a quick question guys on my 410 when driving at speed 45-50 mph on the motorways i am getting a big sway, i have taken all the weight off the roof rack and packed it lower down, springs and shocks seem ok could it be low tire pressures at the moment they are 20 front and 26 rear, it is not the trucks passing or crosswinds
Re: A question of stability
Does it only do it on motorways?? Might just be tramlining. Often on the inside lane 2 small dips form from the weight of all the lorries. Because of the SJs narrow track you don't fit in these and it cause bump steer etc.
best way to avoid it is to drive A roads....it's not like you are in a fast car so why not enjoy nicer more scenic routes
hi Scotty,
Thanks for the swift responce but it happens on normal roads as well
What exactly do you mean by a sway??? As in the sj is steering itself, a wobble, vague steering?
Have a look at the rag joint at the bottom of the steering column. Mine started to go and it made the steering very loose!!!
no the steering is fine it is the car that is rocking from side to side, so much so that if you do not take your foot off the throttle I feel it would topple over
- Edweird
Wow, that sounds really odd. Have you got a tyre bulge perhaps?
- donkeychomp
and why are you running 20psi front 26 rear? The front is way to low.
If you're on standard size tyres try 25psi in the front.
