Hi
I need some help with my Suzuki Alto. Sorry it is not a 4x4 but I thought someone on this forum might be able to help!
I stupidly drove my 2013 Suzuki Alto SZ 1Ltr through the monkey safari at Longleat and the monkeys chewed off the both front washer jet nozzles and the rear one too!
I cant seem to work out if the washer jet nozzle bits were detachable on the front or were actually a fixed part of the molded plastic that lays across the bottom of the windscreen across the front of the car where the wipers come out from. Because of this I am not sure if I should be looking for a complete replacement of the whole molded plastic thing that runs across the bottom of the windscreen or if I just need to buy new washer jet nozzles. I cant seem to find anything online that suggests an actual part name or number for either the front or rear washer nozzle bits.
Any help would be appreciated with part names or part numbers or advice where to buy the parts as I really need to get this sorted.
Thanks for looking!
help needed!
- donkeychomp
Re: help needed!
This may sound a bit like the bleedin' obvious but seeing it's only a year old take it back to Suzuki, point to the parts you need and get them to order them.
Re: help needed!
I would bet a lot.of money on the fact you can order the jets separately. No designer in their right.mind would make them a moulded part of the panel. Way too expensive and complex.
Probably not much from Suzuki. Might as well get the real deal.
Re: help needed!
Thanks for the replies! I was wary of taking it to dealer as thought they would rip me off for something which I may be able to get elsewhere for much cheaper! But thanks for the advice. I will call the dealer in the morning.
Re: help needed!
You may be able to get bits cheaper from a breaker but sometimes you do find that the main dealer isn't too expensive, particularly if bits otherwise have to be posted.
