2" lift Kit
Re: 2" lift Kit
Didnt get that with mine when I did springs and shocks over to ome and it lifted mine from 29 inches to 31 inches so sorry rinoman
Keep the shiny side up. ...
Re: 2" lift Kit
OME struts aren't usually slotted, the holes are drilled in slightly different positions to stock to correct the camber. If you're not getting any scrubbing then they are definitely corrected!
Re: 2" lift Kit
Thanks for explaining that as im a newbie to modifying these ( bring back the 80's) think im having a second youth but in an old body
Re: 2" lift Kit
I fitted 1 1/2" strut extensions to keep the full strut movement and 2" list coil spring , I used the camber bolts set to the max and had to turn them right back because it was like turning up hill when I turn the wheel but now they are set like a standard bolt it feels great and the tracking and toe is correct ?
