Buying lift springs
Re: Buying lift springs
What size lift are you looking for? And what's your budget?
How's your fabrication or do you just want a bolt on solution?
Budget doesn't always define how well the suspension does work, my YJs cost me £150 and I fabricated my own conversion.
From left to right.
Dan. Ironman 2" lift, lowered bumpstops
My own YJ set up with around 1" lift, relocated bumpstops.
Jordi. Llama lift springs front and rear, 50mm dropped bumpstops, stock shackles
Twiss. Lllama lifted fronts. Standard rear on lift shackles.
From left to right.
- image.jpg (345.24 KiB) Viewed 4275 times
My fab skills are good. Im only looking for a couple inches lift
If you can fab go for RUF or YJs or a mix of the two.
Ruf it is i think. Like ladaman, ive a pair of navara leafs for the rear. Just need to start fabrication!
