how much fuel do you use?
Re: how much fuel do you use?
Post by twiss » Mon Jul 27, 2015 1:07 am
With my long distance heavy weight towing I was doing 2 tanks a day haha
Post by ScottieJ » Mon Jul 27, 2015 1:54 am
Mine's terrible on fuel but I do have two transfer boxes and 33s, tbh I never really work it out but I'm pretty sure it's worse than most :lol:
Josh-holden
Post by Josh-holden » Mon Jul 27, 2015 10:36 am
OK, thanks for the reply's guys. when i fill it its about £40 to fill so i would say its a standard tank. ill look into the needle and the spring in the carb. Am i right saying it should have a BFM needle and yellow spring? what's the best place to get a rebuild kit from?
Post by twiss » Mon Jul 27, 2015 3:04 pm
Burlen Fuel systems are the definitive place to go for SU carbs
http://www.sucarb.co.uk
BFM and yellow needle will be fine
Josh-holden
Post by Josh-holden » Fri Jul 31, 2015 2:01 pm
just serviced the carb and put the yellow spring in with the BFM needle. the needle i took out was a BCE and the spring was thin and long. going to put it back on later
Post by twiss » Fri Jul 31, 2015 4:15 pm
Both the SU carbs Ive had came with a really long thin spring... not sure which ones they were but they definitely werent yellow ones!
Post by Jordi » Mon Aug 03, 2015 10:38 am
No idea what spring and needle mine has fitted. Came off a 1.6 Austin / Rover engine so should be somewhere near right. Doesn't use masses of fuel when compared to others. Goes quite well.
Josh-holden
Post by Josh-holden » Thu Aug 06, 2015 12:24 pm
tuning the carb: am i right that clockwise is richer and anti clockwise is leaner?
Post by twiss » Thu Aug 06, 2015 3:45 pm
Yes you are
