Compression test psi ?
lukey4x4
Re: Compression test psi ?
Post by lukey4x4 » Sun Feb 28, 2016 7:32 am
Spot on twiss al give the battery a charge and will do that , looks that way he gunna get wrong when a see him mate lol , ok al get the new waterpump on and get it tested after that al post bothe readings , cheers for the help ,
Post by ScottieJ » Sun Feb 28, 2016 4:22 pm
twiss wrote:You should always do a compression test when the engine is at running temperature! Otherwise it will always give low readings!
Also you MUST have a good battery to have the starter turning as fast as it can.
And hold the throttle wide open while doing the test.
lukey4x4
Post by lukey4x4 » Sun Feb 28, 2016 5:54 pm
Cheers scottie will do that mate
