Removing middle pin from astra shocks?
Re: Removing middle pin from astra shocks?
My flex was cack with the add-a-leaf springs even after my usual battering the shit out of them!
I must have just got really lucky with mineScottieJ wrote:maybe our idea of 'loads of flex' is differentROBBIE wrote:Used to get loads of flex on mine, just such a bloody uncomfortable ride. But they will probably destroy your top leaf as on compression it dose tend to bend it the wrong wayScottieJ wrote:Then again add a leafs are so stiff you probably won't get it to flex that muchhorrible things
it's not gonna flex any better than standard with add-a-leafs
Confession time. After looking through some old pics and paper work. I only had two leafs and the aal per corner, I suppose that would help flex?ScottieJ wrote:maybe our idea of 'loads of flex' is differentROBBIE wrote:Used to get loads of flex on mine, just such a bloody uncomfortable ride. But they will probably destroy your top leaf as on compression it dose tend to bend it the wrong wayScottieJ wrote:Then again add a leafs are so stiff you probably won't get it to flex that muchhorrible things
