Post
by twiss » Wed Jun 15, 2016 11:50 am
My samurai has the plugs as well but ive never had any issues getting them undone with the square end of a socket wrench.
If they give you some trouble show them a bit of blowtorch
SlimGrim
- Winching along now
Post
by SlimGrim » Wed Jun 15, 2016 11:57 am
this is a surprisingly transferable technique for people too
___________________
zook123
- SCUK Addict
Post
by zook123 » Wed Jun 15, 2016 2:29 pm
Yeah the transfer box undone easy, but the gearbox fill plug rounded off, had to get a mate to weld a nut on there!
Trying to get the diffs undone is proving somewhat a pain, so I'm going to have to buy some proper tools!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
dan00001
Post
by dan00001 » Mon Jun 20, 2016 2:45 pm
So I took out the fill plug for the transfer box on the weekend, there was plenty of oil in there but it was yellow?
Are some oils yellow? Or do you get additives or anything?
Thanks.
zook123
- SCUK Addict
Post
by zook123 » Mon Jun 20, 2016 2:48 pm
Yellow, or Golden?
dan00001
Post
by dan00001 » Mon Jun 20, 2016 5:54 pm
I would say more like bright yellow! But my memory could be playing games, I was doing a lot that day, I might take another look tonight.
Think I might just do an oil change anyway. Its the same, 75w90 right?
Post
by ROBBIE » Mon Jun 20, 2016 10:27 pm
Full of water. I had the rubber gaiter go on a t/box and when I went wading it would fill up and go yellow as it got churned. Post up a pic of it
Post
by twiss » Mon Jun 20, 2016 10:31 pm
If it looks like this its got loads of water in it and needs replacing asap
dan00001
Post
by dan00001 » Tue Jun 21, 2016 10:28 am
Yes! That is exactly how it looked !!!
I will be changing the oil today straight after work!
Does this mean there's a water leak somewhere in the transfer box?
Thanks for your help in identifying this (y)
SherwoodNash
Post
by SherwoodNash » Tue Jun 21, 2016 1:19 pm
dan00001 wrote:Yes! That is exactly how it looked !!!
Driving through deep water In it's past life, your SJ may have had water sucked in by vacuum into the hot case, via the breather tube.
So hopefully not necessarily a leak
Take a gander at this article:
http://www.suzukiclubuk.co.uk/diy/16-tr ... -breathers
