Page 2 of 3
Re: Hello folks
Posted: Mon Apr 24, 2017 2:50 pm
by Madprof
My buggy is roughly sj 413 but open to be adapted. Sadly found bellhouseing cracked thru at starter area back. Could be welded or seek left overs from someone's upgrade. I'm in my 50s so struggle on PC so learning as I go. Thanks for the advice. Much appreciated.
Re: Hello folks
Posted: Mon Apr 24, 2017 9:26 pm
by Anton
I think that the point Scottie was making is that the 410 bellhousing won't do a 413 owner much good as the G13 engine in the SJ413 is a significantly different bolt pattern to the F10 engine in the SJ410. You need a 413 gearbox unless you are downgrading to the 1.0.
Re: Hello folks
Posted: Mon Apr 24, 2017 11:07 pm
Yeah that's what I was trying to say. Just got a. It confused by your post about a 410 gearbox when you have a 413. Let me check. I might have a spare 413 gearbox and I'm not far from you.
Re: Hello folks
Posted: Wed Apr 26, 2017 11:54 am
by Madprof
Hi guys, I'm afraid we got a bit of a tangent. I'm in need of 413 bellhouseing or box. Where I read people have gutted 413/5 speed boxes to put in the 410 cases I'd settle for their leftovers but hey if you're able to sort a whole gearbox well that would be golden!!! An like you said you and I are near enough. Fingers crossed
Re: Hello folks
Posted: Fri Apr 28, 2017 2:43 pm
by Anton
Complete 413 gearboxes aren't rare, if Scottie doesn't have one, then try Andyrew or Mike Harris.
Re: Hello folks
Posted: Fri Apr 28, 2017 3:59 pm
I'll check this weekend for you
Re: Hello folks
Posted: Fri May 19, 2017 8:21 am
by Madprof
Back in the shed friends. Unearthed the transfer box for a clean up and check mountings. After reading here I'm curious as to how you tell the small prop version? First SJ I've owned so don't know so much. Do appreciate your help out there
Re: Hello folks
Posted: Fri May 19, 2017 11:50 am
by palo123
Skinny props are on sj410 built before 1984 i think, it might be 85.
You can also tell by measuring the flange bolt spacing, where the prop bolts to the diff or the transfer case. If the bolt spacings are 56x56mm on centres they are the fatter props and if smaller bolt spacing they are skinny props.
You can also see quite clearly as skinny props are around 40mm in diameter (measured by my eyechrometer
The skinny propped sj will also have a metal dashboard.
Pete
Re: Hello folks
Posted: Mon May 22, 2017 1:13 am
by Anton
Yeah, pretty sure no 413 or samurai came with skinny props. 99.9% certain that you have a fat prop tcase.
Re: Hello folks
Posted: Mon May 22, 2017 11:27 am
by sidsuzuki2346
I've got a 413 box if you still need one
