2" Body lift
felstmiester
Re: 2" Body lift
Post by felstmiester » Sun Mar 20, 2011 7:48 pm
all i done was loosen the fuel filler hose at the top, take the bolts out the brake line mounts in the drivers side wheel arch, unbolt the fuel filler guard as the top is bolted to the body and the bottom to the chassi and just unclip all the wires underneath. It was an easy job, but only because we made up some special studs with stud extenders so we didnt have to cut the existing one's off the body.
suzuki matt
Re: 2" Body lift
Post by suzuki matt » Tue Mar 22, 2011 9:14 pm
all pretty simple will give it a go ;)
1987 SJ416 lwb pick up, vit 8v engine on su carb, 1.0ltr trans box, spoa conversion, twin winch, full roll cage, 31x10.50R15
1990 SJ410 santana soft top very much standard 1 0wner from new 50,000 mile on clock in need of a welder and TLC!!!
