it did have an run fine taken it off when the problem started.
sorted it now it was cold 2 cold put the worm air pipe on.
opend the flap sorta. ant got it no more so is derect
Weber carb set up 32/36 DGV
Re: Weber carb set up 32/36 DGV
Sorry for late reply, new member just joined. Sounds like accelerator Jet blocked or damaged diaphram. Diaphram is located under four screws above pipe A in Tramp's photo, The jet is visable with air filter removed just inside venturie/carb. With engine off and a sudden push of the gas pedal you should see a good squirt of fuel from jet. if blocked or only a dribble of fuel it will give the exact symptoms you describe.
To clean you either have to strip carb or sometimes you can clean by revving engine to quite high revs, (with airfilter removed) Then release throttle, Before the revs drop down cover the top of carb with the palm of your hand untill engine dies. Will make you jump if you havent done before as will suck your hand down onto carb as being starved of air. The resulting extra sucking will usually clear the blocked jet.
Hope this helps Paul.
