Newtomud
- Can I have a tow
Post
by Newtomud » Sat Sep 24, 2011 6:15 pm
bigben wrote:i sure will bud i was a busy bee that day mate 400 houses to deliver to and it was wayy past opening time on a friday haha oh and no i dont smoke mate dont think i could have nicked it either it was on stands lol
How are you finding the springs now? i may go down that route myself as my add a leafs are wayyyy to harsh for me, got to get going with her again soon for the winter
Please don't get me wrong, I wasn't accusing you of trying to nick it... I just got a bit worried when I found a rolly butt stubbed out next to the SJ as it's nowhere near the foot path.. Someone else must have been having a look at it, just hope it's not a thieving scum bag eying it up.
The springs give loads of lift and seem to do a good job.. The tyres are a mother on the road but are great off road. Not sure about the shock extensions?
Newtomud
- Can I have a tow
Post
by Newtomud » Mon Oct 03, 2011 4:56 pm
Started to take the boot floor out..
- 002.JPG (666.15 KiB) Viewed 7124 times
Bought a sheet of steel 2.5m x 1.25m.Just need to buy some 20x50mm box section for the brace that goes under the floor.
Jet washed the chassis and it came up good as new.
Wouldn't mind fitting a petrol tank in the boot
Newtomud on Sat Jan 26, 2013 11:12 am, edited 1 time in total.
- The Boss
Post
by ScottieJ » Tue Oct 04, 2011 5:23 pm
You need something with a return feed or to just fit a return feed! looks quite nice though, it can be a pain in the ass not having a fuel gauge but I'm sure you could make an SJ one fit it.
Newtomud
- Can I have a tow
Post
by Newtomud » Tue Oct 04, 2011 6:19 pm
ScottieJ wrote:You need something with a return feed or to just fit a return feed! looks quite nice though, it can be a pain in the ass not having a fuel gauge but I'm sure you could make an SJ one fit it.
Silly question time..
Could the brass connecter be used as the feed.. The other outlet used as the return.. Then all that is needed is a breather?And a breather could be drilled into the filler cap and a hose attached?
Would I need an inline fuel pump?
Not too bothered about the fuel gauge.. I've ridden motorbikes since the mid 70's and most of them haven't had a fuel gauge..
(Blimey just thinking about how many bikes I've had.. Suzuki TS250 - Suzuki GT250 - Honda 400 dream - Honda cb750f1 -Honda cb650 Nighthawk - Suzuki GS850 shaft drive - Kawasaki Z650 - Kawasaki ZX10 - Kawasaki ZZR1100 - Kawasaki ZX7r Ninja - Kawasaki ZX9r Ninja - Kawasaki ZX12r Ninja )
- The Boss
Post
by ScottieJ » Tue Oct 04, 2011 7:39 pm
Yes you could do that, or you could find someone who can tig weld and put a return feed into it, the stock pump will work fine
Team Pink
Post
by Team Pink » Tue Oct 04, 2011 9:12 pm
I had a tank very similar to that when I first built the racer. The wall thickness is about 1mm. It lasted 1 season before the weight of fuel bouncing about stress fractured one of the seams. I now have a custom built Alisport tank. I do not think that rally style tanks are up to off-roading.
Newtomud
- Can I have a tow
Post
by Newtomud » Thu Oct 06, 2011 6:07 pm
ScottieJ wrote:Yes you could do that, or you could find someone who can tig weld and put a return feed into it, the stock pump will work fine
Could fit a clear plastic sight pipe on the side of the tank as a fuel gauge as well??
Team Pink wrote:I had a tank very similar to that when I first built the racer. The wall thickness is about 1mm. It lasted 1 season before the weight of fuel bouncing about stress fractured one of the seams. I now have a custom built Alisport tank. I do not think that rally style tanks are up to off-roading.
Maybe some of that fuel tank foam and some good strong ali straps around the tank would do the trick as I'm not racing... I probably won't get over 10 miles an hour when off roading??
Newtomud
- Can I have a tow
Post
by Newtomud » Wed Oct 12, 2011 6:24 pm
Sent my transfer boxes of to
ROCKWATT today
Post
by dan_2k_uk » Wed Oct 12, 2011 8:06 pm
Looks like its a race. Ive just
sent him my inlet manifold for SU conversion.
Trucks looking real nice. Keep up the good work
