Page 2 of 2
Re: Waterproofing
Posted: Tue Sep 18, 2012 9:22 pm
by Tramp
Yeah upside down box, parting the casings and I've heard of putting grease in the hole so it catches the swarf,
Re: Waterproofing
Posted: Tue Sep 18, 2012 9:58 pm
by Christoff
Bloody hell big job just for some axle breathers. It's on my list of mods to do anyway. Is there some kind of join you can get so all 3 breather hoses can go into one outlet somewhere?
Re: Waterproofing
Posted: Tue Sep 18, 2012 10:10 pm
by Tramp
Bits4vits used to do a kit, I used vaccum hose and Y connectors with jubilee clips from my local automotive shop, you only have to do the tapping on the t box, the axles have a longer stub so you can clip straight on, i only did my tbox because I was taking my tbox out anyway
Re: Waterproofing
Posted: Tue Sep 18, 2012 10:15 pm
by Christoff
Axles sit lower anyway don't they. It would be rare I go through water as deep as the top of the transfer box I think, Must be at the sill line or above.
Re: Waterproofing
Posted: Thu Sep 20, 2012 12:59 pm
by tonsky
thankyou all for your input this is great ill be out there on saturday with my WD40 and checking on the breather hoses etc.
I think water did soe damage to the starter motor last time but we maaged to clean it up and get it running again. No way to waterproof them i suppose?
Re: Waterproofing
Posted: Thu Sep 20, 2012 1:39 pm
by Highlander
I've tried it with silicon etc but i think the water just gets in via the bell housing
Re: Waterproofing
Posted: Wed Mar 27, 2013 11:55 pm
by The Heretic
Sorry to drag up an old thread. My bro and I did the breathers on my Vit a few eeks back with some garden hose. His breather caps as like little spring loaded caps, that can move up and down. I don't know much about these connectors at all, or about the pressures inside a diff. Is it worth extending these breathers, or is the little springy cap thing a bit like a snorkel? Would the diff suck air in as it cools, therefore water?
No idea, so, do you need breathers, or not? begrudge doing something if we don't need to.
Re: Waterproofing
Posted: Thu Mar 28, 2013 4:39 am
by kiwizook
your diffs will warm up when you drive around, and will rapidly cool when you hit water or mud, and the pressure inside the diffs drop, sucking in air. if the breather is in the water or mud, it still needs to suck something in, so it will suck in water or mud, whatever is around the breather. so to prevent this you need diff breathers, which is like a mini snorkel, so it will always suck air, and no crap.
the springy caps need to be pulled off, and the hose fitted over the pipe that sits under these springy caps
Re: Waterproofing
Posted: Thu Mar 28, 2013 9:57 am
by The Heretic
Cheers.
