Propshaft info
Re: Propshaft info
Post by ScottieJ » Mon Apr 22, 2013 10:38 pm
I thought thats what you meant but had to check. I've never known one to wear within the yoke :er: what were the measurements? Of both the bearing cap and yoke? I suppose its possible someone fitted the wrong size UJ causing it to wear.
HuwJones
Re: Propshaft info
Post by HuwJones » Mon Apr 22, 2013 10:57 pm
I'll get the paper with the propper measurements from the garage tomorrow. There was about +-0.65 in the diameter of the yoke and +-0.40 ish in the other bit (Bearing cap? I'm not sure what you call the bit in the middle)
Huw
There's three ways of doing things,
1) The Right Way,
2) The Wrong Way
3) My Way.
2 & 3 are usually the same.
HuwJones
Re: Propshaft info
Post by HuwJones » Mon May 27, 2013 4:57 pm
I took the prop shaft off over the weekend. The slightly worn bit I was talking about, it's not much compared to the other end. I failed to notice it when observing the other end, there was too much mud and grease filling it in.
The only way I can guess that this happened are
1) Had a knock at some point.
2) Bearing being incorrectly fitted last time it was changed.
3) It giving up due to 20 years of work!
Within 20 mins of finding the fault, a replacement prop shaft was purchased off eBay.
Now I just need a new exhaust system…
1) The Right Way,
2) The Wrong Way
3) My Way.
kiwizook
Re: Propshaft info
Post by kiwizook » Sat Mar 04, 2017 8:49 am
found a really great vid explaining driveshafts and angles etc, thought I would share it
https://www.youtube.com/watch?v=5aCK4Bob6a0
Click Here for Youtube Video
Rabid Rhino
Re: Propshaft info
Post by Rabid Rhino » Thu Jul 06, 2017 2:12 am
Video = Mind Blown.
Any chance on filling in the table with Rear Prop Shaft Lengths ? Especially the LWB. Flange to Flange would be great.
