New to site. My build so far!
dannytrigger
Re: New to site. My build so far!
Post by dannytrigger » Fri Feb 01, 2013 7:41 am
Thanks guys! Im always open to advice and opinions thats the whole idea of joining. Definatly gona look into halfshafts maybe build on a pair of strong axels of the truck then just roll them under when i am done.
Post by dan_2k_uk » Fri Feb 01, 2013 9:22 am
:welcome: to SCUK dude
Thats big! I would do as Scottie says and try get the COG down a bit if you can.
Dan
dannytrigger
Post by dannytrigger » Fri Feb 01, 2013 11:11 am
been on to rs-mfg today just awaiting a quote for 8:1 gearing t box and full floater axel kit!
Post by ScottieJ » Fri Feb 01, 2013 11:23 am
I think you might be better off re gearing the diffs with some 5.12:1 vitara ring and pinions and then a rocklobster to be honest, it will take the strain off the rest of the transmission and then get a rocklobster built by rockwatt to give you 4.16:1 low ratio it will work out cheaper and give you a good reduction.
Or the 5.12 diffs and a 6.1:1 tbox would work really well.
dannytrigger
Post by dannytrigger » Fri Feb 01, 2013 11:40 am
just been reading up on this and looks like a good option gonna have look for some front diffs on ebay and get to mork fitting them! may aswell up rate half shaft whilst i am in there i suppose? whats your thoughts on using a complete rear axel from vit and welding some perchs on it?
Post by ScottieJ » Fri Feb 01, 2013 2:01 pm
The Vit rear axle is a good option as it has a bigger, stronger diff. However it is quite a bit wider than a front samurai axle and then if you converted it to a full floater it would end up another 3" wider. One option would be to get it cut down to the same length as a samurai rear axle and then it would also end up with an offset diff. Abdul from the raging rhinos in Kent does this for a pretty good price.
You will need uprated shafts either way with 37 :brows:
Post by Jordi » Fri Feb 01, 2013 5:16 pm
I was onto Rockwatt the other day and his prices for new gears are pretty competitive. Saves having to source a 410 box.
As mine was so cheap i'm just getting the gears cut. He can supply and fit all different ratios. It was the first time i spoke to him and much like some of the chaps on here, a fountain of knowledge!
I think so long as you've got cash he can make anything you want. Quite pleased he's only at Scunthorpe.
As i intend spending as much as i can for the next few months till i have to save for family stuff.
dannytrigger
Post by dannytrigger » Fri Feb 01, 2013 6:42 pm
thanks for all the adice guys. I have orderd full floating axel kit and having a transfer box built with custom gears. judt gotta wait for it all to turn up now!
Post by ScottieJ » Sat Feb 02, 2013 1:24 pm
Nice! Do have to ask is this one going to be road legal or just for pay and play days etc? If its not gonna be road legal then there's a few things if recommend doing to get it lower and that will help its offroad performance.
dannytrigger
Post by dannytrigger » Sat Feb 02, 2013 3:28 pm
yes will be full road legal mate. ye think may drop body lift
