Wheel spacer question ?
Re: Wheel spacer question ?
Got a spare jimny pump i think.
Edit:- also may have pulleys too.
Vit pump and jimny box is as bolt on as it gets.
Still need to modify pulley if it isn't a 1600 and modify the pump bracket or rad mount to avoid fouling.
Somewhere in my build thread there is a post I wrote as a mini guide for Tom.
Jordi I'm runing a 1600 vit engine. Have you got the full set up for sale
Nah. I bought the full jimny set up to go onto a 1300. Now i'm gonna fit the vit lump it came with all pulleys and pump. All i need is the jimny box and pipes.
Just jimny pump and bottom pulley to get rid of i'm afraid. NE motor salvage at peterlee did have a jimny in. Probs cheaper on the bay though. Not sure if jimny pump and vit pumps are the same?
If they're different might be easier to get a vit pump and it'll bolt straight on. If no one knows i'll compare.
Not quote so local but theres a scrappy called UK parts (used to be bells breakers). They're at shildon and we always reasonably priced. Whessoe rd salvage in darlington had a vit in.
When i'm home i'll sort through and see which bits i have if you want.
Ok yeh just let me no ill see if I can source other parts
All you should need is a pump, pipes and steering box. As long as you have all original vit pulleys.
Almost a bargain. I paid £100 for box, pulleys, pipes and pump. Delivered.
For a new Jimny box I though that was superb. I paid the same for a used one.
