Page 2 of 2
Re: KJA build
Posted: Mon Aug 26, 2013 11:13 am
by ianedwards
Hi, thought i had seen it some where. (ebay)
nice to see another kja build, good luck. got a bit more to do on mine but its nearly there. if you want some advice just ask.
Ian
Re: KJA build
Posted: Tue Sep 24, 2013 1:39 pm
by OllieSJ
I really like that any news on the build ??
Re: KJA build
Posted: Wed Sep 25, 2013 9:54 pm
by Jack6835
Not been on here a while been flat out at work but I have been doing some bits to the anus/buying goodies whilst at work, got myself a winch bumper,some pro comp shocks and some kumo road Ventura mt for £100 but apart from that I've painted the inside of the front tub,done the clutch,water pump and cam-belt,and I've spent the last two days trying to wire up indicators and headlights as some bodger before me had about a million wires connected to the headlight doing nothing so I striped it back and re wired it and I also had to un plug the (Spanish headlight relay thing?)
### few questions,
My anus has got the vin number/plate to say its Spanish built but it has the round indicators switches,is this normal?
My anus came with a 1.6 conversion but the intake hits on the bonnet so it won't shut properly what can be done about this?
Were can I get a fuel pump gasket?
I have some very un happy looking springs and I've heard bad things about add a leaf and don't want to buy lift springs because its already spoa,is there anywhere I can buy standard leaf springs or some that will fit?
Thanks for the help,will get some more pictures up soon
Re: KJA build
Posted: Wed Sep 25, 2013 10:12 pm
by donkeychomp
Nice zook! I think the round indicator stalks were Japanese only...could be wrong though...
Re: KJA build
Posted: Wed Sep 25, 2013 10:18 pm
by dan_2k_uk
How high the 1.6 is will depend on the carb fitted. If it has a SU conversion on a adapter elbow they are normally too high so you could swap to a custom manifold from Rockwatt.
The fuel pump gaskets normally come in the headset kits so must be about to buy individually too.
Re: KJA build
Posted: Wed Sep 25, 2013 10:35 pm
If thats the only gasket you need just get a sheet of gasket paper and cut hour own. Its easy enough.
