Bump Stops
Boyes
Re: Bump Stops
Post by Boyes » Tue Sep 03, 2013 8:00 am
Not sure how for off the mounting holes are, but if you're extending with box section you could drill the box section to suit;
Click Here for Ebay Listing
or
Might be a cheaper way :thumbup: and spend your hard earned elsewhere.
NylonAdmiral
Re: Bump Stops
Post by NylonAdmiral » Tue Sep 03, 2013 9:11 am
Thanks guys.
Mike, nice looking setup! That's similar to what I'll probably end up doing.
Boyes, if my current ones are no good I'll probably get something like that, looks like a much better option!
Re: Bump Stops
Post by ScottieJ » Tue Sep 03, 2013 9:24 am
I just run stock bumpstops but the front mounts have been moved inboard to help flex.
Stock fronts just bolt straight on.
I'm about to change the rear set up to use standard front bump stops as well.
NylonAdmiral
Re: Bump Stops
Post by NylonAdmiral » Tue Sep 03, 2013 9:59 am
Brilliant, thanks for that.
Another thing I wanted to ask was what people's thoughts are on bending axles.
How hard do you have to push it before you're at risk of bending them?
I mostly just do laning but will have a go at pretty much anything :)
Anyone who has bent an axle, what were you doing at the time?
Thanks!
kiwizook
Re: Bump Stops
Post by kiwizook » Tue Sep 03, 2013 10:56 am
wait for mike harris :D
Re: Bump Stops
Post by ScottieJ » Tue Sep 03, 2013 11:34 am
Jumping and hard landings are what bend axles, just laning and occasional pay and plays you'll be unlikely to bend an axle, I've only bent one in 7 years.
NylonAdmiral
Re: Bump Stops
Post by NylonAdmiral » Tue Sep 03, 2013 1:17 pm
I'm guessing Mike's maybe managed to bend a few then? :)
Thanks Scottie, I try not to get too much air in the truck so should be OK!
Re: Bump Stops
Post by mike harris » Tue Sep 03, 2013 7:27 pm
I could win a gold medal in it !!
Re: Bump Stops
Post by mike harris » Tue Sep 03, 2013 7:31 pm
I have only bent both my axles like a banana due to running silly offset wheels and wheel spacers, and having my axles not trussed properly, and not strengthening the swivel housings either. I have broke standard Sjs in the past with bent axles, but they have been through abuse.
Not to say I don't abuse my suzuki but you can't blame my axles bending when you think of the huge strain they are under. I am at the point now that if they bend or something major breaks in my axles I will go mad and mog axle it. But I don't want to do it but it will benefit me financially, as in the long run I won't need to buy axles, shafts, diffs, lockers ECT.
NylonAdmiral
Re: Bump Stops
Post by NylonAdmiral » Tue Sep 03, 2013 9:39 pm
Ha ha, well hopefully I should be OK then! Thanks Mike.
