Probably need to extend chassis stops 50mm.
Try it. As long as it hits the stop before the spring goes past flat or the shackle gets to 90deg it'll be fine.
If your shackle gets to 90deg before the spring is flat it means the spring is longer than the gap between the hanger and shackle at full extend so your spring ends up doing all kinds of bad things. Hope that makes sense.
bump stops
Re: bump stops
- timwilks13
- SCUK Website Padawan
Re: bump stops
Are the chassis stops the bits that the bump stops hit against? If so I can just weld on some 50mm box section yea?
- Edweird
Re: bump stops
Exactlytimwilks13 wrote:Are the chassis stops the bits that the bump stops hit against? If so I can just weld on some 50mm box section yea?
- dazerede
Re: bump stops
Um not sure best option is to jack it up and when the springs go flat thats how big the bumpstop needs to be mate
4” calmini lift kit
4” calmini lift kit
