Rear seat for the SJ413.
Re: Rear seat for the SJ413.
Easily removed, 4 bolts in each! the rearmost bolts should have wing heads on so they can be removed by hand and so the seats can pivot forward if you need a larger load area, when they left the factory these twin rear seat types had a bit of leather attached where the front seats inertia reel seat belt is which hooked on a peg on the bottom of the twin seats to keep them in the pivoted forward position,
Blimey that sounds perfect for what I have planned, need to install a removable high single seat in mine (not for occupancy during off-road use, mind!). Good info again, I like this forum.
