Page 14 of 36
Re: Project Bodge
Posted: Tue Oct 19, 2010 6:00 pm
by Henry
Yerp i run a rockratt one to. Really carnt beat him for quality. I think Nigel head has packed up doing them now.
Why not try some vit ring and pinions first?
Re: Project Bodge
Posted: Tue Oct 19, 2010 10:50 pm
by 4eye
lookin smart there ferris....must pop over at some point an have a butchers first hand......still havent fixed mine yet but it shouldnt be that long till i pull out me finger...plus the wifes geettin pretty narcked cartin my arse everywhere
Re: Project Bodge
Posted: Fri Oct 29, 2010 7:21 pm
by ferris
Got my MOT first thing in the morning
Im pretty sure every thing is up together. Fingers crossed.
Re: Project Bodge
Posted: Fri Oct 29, 2010 7:35 pm
Good luck! i always go around and check all lights and the horn before the test just to be sure. oh and dont forget to ask them to adjust the headlights for you first as they might be out now it has a bit more lift and youve fitted the golf ones
Re: Project Bodge
Posted: Sat Oct 30, 2010 5:11 pm
So??????????
did it pass????
Re: Project Bodge
Posted: Sat Oct 30, 2010 5:51 pm
by ferris
Well it failed
nearside headlight had no pattern
offside brake light not working
brake pedal anti-slip provision missing
front wheel bearing excessive play
hand brake was poor
offside rear drum not effective enough
brake lines leaking on bias valve
But i managed to sort all that out in a hour and got back up there 5 minutes before he closed. He retested it and........
IT PASSED
Re: Project Bodge
Posted: Sat Oct 30, 2010 5:58 pm
:smoke: Nice one! Glad to hear it! we'll have to head out once mine is back on the road.
Re: Project Bodge
Posted: Tue Nov 02, 2010 7:13 pm
by ferris
Well iv been on the road for a few days now, and a number of issues have arisen so far.
Iv got oil leaking from the back of the engine, not sure where at the moment.
A knocking coming from somewhere when slowing down between 10mph and 0mph. Think it might be one of the front wheel bearings.
The indicaters flash really fast.
The idle speed seems a bit high, when the auto choke is on, it ticks over about 2800rpm and then settles down to 1000rpm
Other than that it seems pretty solid, and not to bad to drive. Apart from trying to get out of tight parking spaces, the steering is ruddy heavy
Re: Project Bodge
Posted: Tue Nov 02, 2010 8:04 pm
by 4eye
Congratz fer the pass....a sj is a labor of love.....and it always needs the love
Re: Project Bodge
Posted: Tue Nov 02, 2010 8:29 pm
righto! oil leak will be either the dizzy housing, fuel pump or rocker cover gasket.
The fast flashing should have failed the MOT so I presume it wasn't at the time of MOT? One of the indicator bulbs/earths must've failed as fast flashing is a sign of too little resistance in the circuit. Is it just one side or both?
There is a choke idle adjuster screw on the carb I think, cant remember which one though, will look for you. or it could be something to do with the idle up if you have that set up.
And yep 33x12.50s without power steering is a good workout
I've got power steering to go on mine when i put it all back together.
Scott
