Page 3 of 3
Re: Engine Identification
Posted: Sun May 31, 2015 2:01 pm
by Beardy89
Ok so finally got round to buying a compression tester and doing a compression test. Results below.
Measured in PSI.
WIDE open throttle.
After some further testing it appears as though my budget compression tester underreads by around 60psi.
Meaning my results are:
1 = 160psi
2 = 160psi
3 = 150psi
4 = 160psi
From what i've read this is ok for an engine with around 80,000miles on it.
Where to go next?
TPS?
Exhaust leak?
Lambda?
ECU?
Posted: Sun May 31, 2015 8:44 pm
by Rhinoman
A leak from the exhaust manifold will throw the O2 sensor reading off and cause it to run rich, that is well worth investigating, a new O2 sensor would be a good investment too.
How did you determine that your compression tester was out by 60psi?
Posted: Sun May 31, 2015 9:23 pm
by Beardy89
Rhinoman wrote:A leak from the exhaust manifold will throw the O2 sensor reading off and cause it to run rich, that is well worth investigating, a new O2 sensor would be a good investment too.
Rhino. I used my air compressor with a high quality pressure gauge. Connected both gauges to the compressor and ran it up through various pressures.
I will order a new lambda sensor. Would a leak from the exhaust manifold cause issues like this?
Posted: Sun May 31, 2015 10:31 pm
by donkeychomp
160 is low but ok, my 410 engine is 175 on all 4. And it's done a lot more miles!
Posted: Tue Jun 02, 2015 10:54 pm
by Beardy89
Changed lambda tonight. Seemed to make a slight improvement.
Think the next step is to seal the exhaust leak from manifold. And to peform the TPS test and adjustment.
After that I am out of ideas.
