Anton wrote:Nicer how, Scottie? I know as much about shocks as I do about Opera.
I know I want mine very long for good articulation, but I don't know what makes one shock "good" and another "not so good"...
A very simple question, answer not so simple.
My tongue in cheek reply was correct, Fox and King are the best (and top of the range Bilstiens), £200+ per corner for the basic shock.
So what is the difference between a Fox and a "white body shock
Fox
Rebuildable, every single part available
Build quality, S/S shafts with thick chrome plate, High temperature seals and oil
Tunable, the huge advantage. you can tailor the damping to suit your vehicle.
Separate reservoir so constant damping
White body
Emulsion shock, oil and nitrogen in the same tube, forms an emulsion as it is worked therefore damping rate can vary
Cooling compromised as they are often twin tube
Made to a price point therefore quality of shafts seals etc not the best.
Not rebuildable or tunable
How do they compare in the real world.
For most uses a good white body is perfect, shafts will get damaged, rusty etc and screw up the seals, need to be replaced every so often but cheap enough
Fox etc are more for competition, where they can be tuned to suit the vehicle and expected terrain.
I have raced on both, the Fox shocks are worth at least 10 seconds per mile!
