Re: Vitara pick up project
Posted: Sun Mar 31, 2013 5:49 pm
got a lot more work done over the last few weekends including the winch bumper and assorted mountings:-
i got a land rover winch bumper form ebay quite cheap and decided to see if i could make it fit, and here it is,
i used some flat 6mm plate and using the front body/chassis mounts just made them protrude enough to use the original bolt holes from where the l/rover bumper sits.
i then welded some angle to allow the use of the side bolt holes from the original bumper mountings at the front/side of the vit chassis.
i then welded some angle to the front of the chassis to allow it to meet up with the other lower mounting point on the l/rover bumper,
i have tried to test fit the winch as well but still need to use a plate as the original winch mounts on its side on this bumper,
as the bumper has a rounded bottom the only flat area is either end so needind this 6mm plate to mount the winch onto,
it does look a bit lost as the original winch is much bigger.
the other problem is the fairlead as the bolts holes also do not line up so i have made this ally plate to mount the fairlead to,
i am going to mount the solenoid box under the bonnet so that is another job to do once the winch is in place.
lots more next time,
shaun
shaun
