Today has been a good day, as i can finally see what it is going to look like when its finished.
But first, i took the brake line off the rear axle last night, popped it into the garage this morning with one of the flexi pipes from the 600 callipers. They have put the right ends on, which means i can now plumb in the rear axle.
I fitted the other side of the callipers, with new brake pads on the rear... All that is left to do, is figure out how to mount the handbrake on the callipers so it all works.
One of the front callipers needed changing, so i did that along with the pads on both sides of the front...
As you can see they are well warn!
I also fitted the electric fan, this is wired into a on off switch. It will remain on all the time (it goes off when the ignition is turned off like the fuel pump) but the switch enables me to turn it off when wading. I may also switch the fuel pump (undecided)
Refitted the painted shocks
And then put the new rubber on....
Sadly still not moving under its own power, ive got a couple of prop UJS to do, but i carnt for the life of me find my cir-clip pliers!
Henry
