Hi guys I'm new.
Re: Hi guys I'm new.
Ha I thought it would be easy too.
I've come to fit and the plug and bracket don't match,, any ideas please
- image.jpg (95.05 KiB) Viewed 5106 times
- image.jpg (102.57 KiB) Viewed 5106 times
What's your plan.
Get the correct alternator or make it fit/work..
Would it be possible to change the plug??
Have you seen this plug before because I can't find one like it online.
Cheers ..
Cheers ..
Fairly sure that is the Japanese plug / alternator
Where is best place to get the right one for me. I'm guessing I need a Spanish one.
- suzukisteve
- Suzuki Guru
id say pop down to your local motor factor. take that one with you so you can show em whats wrong with it
pickle power!
I think I have a spare plug for that alternator do you want it?
Or if you can't be bothered with the plug....
ring connectors on the ends of the white and yellow wires... then connected to terminal B in the pic... then spade connector on the white and red wire, connected to (i think) the right side pin (in the pic) of the alternator socket
if the dash battery light doesn't come on with the ignition, its a different pin
I prefer those alternators as I think it's the one with the internal cooling fan.... doesn't spray mud and water across your engine bay that way
Cheers guys. That plug would be great cheers
- timwilks13
- SCUK Website Padawan
you could just put some spade terminals on the relevant wires and just push them onto the correct pin? there is a picture of that alternator wiring here if you need http://forum.suzukiclubuk.co.uk/vi ... =11&t=5383
