just bought my first sj samuri :)
mmac78
Re: just bought my first sj samuri :)
Post by mmac78 » Sun Jul 13, 2014 7:26 pm
Before I'd even begin putting time into it, I'd find out it's history first. Find out if you can obtain a new V5 or all of this work will be worth nothing to be honest.
Enthusiasm is good though, you're more than welcome to come and sort mine out while you wait for your V5 lol.
Jordanquin
Post by Jordanquin » Sun Jul 13, 2014 7:29 pm
Haha ok. I'm going to ring dvla tomorow, I think I've found a vin number down by the drivers footwell, but would I be better to try and find one on the chassis incase it's had a new body??
mmac78
Post by mmac78 » Sun Jul 13, 2014 7:42 pm
Yeah i'd try looking, the chassis number is behind the drivers side wheel stamped on the chassis next to the brake pipe retaining bracket.
Jordanquin
Post by Jordanquin » Sun Jul 13, 2014 9:19 pm
Yeah I have found that one but someone said there will be another one on the chassis somewhere?? What one would be better to use if they do differ and would it be worth finding both to see if they match??
mmac78
Post by mmac78 » Mon Jul 14, 2014 10:09 am
if the one in the footwell doesn't match the one stamped on the chassis like I mentioned, then you've two different cars and probably won't be worth continuing until you get word from DVLA.
Post by twiss » Mon Jul 14, 2014 10:14 am
Its not really so much of a problem with SJs (and many other 4x4s) as you can freely take the body off one and put in on a different chassis...
If the numbers are different though make sure you use the chassis one and not the body one ;)
Post by ScottieJ » Mon Jul 14, 2014 12:09 pm
twiss wrote:Its not really so much of a problem with SJs (and many other 4x4s) as you can freely take the body off one and put in on a different chassis...
If you have a VIC and the body vin plate does not match the chassis number then Vosa will not be very happy, they need to match so if the body is swapped the vin plate needs to be as well.
The VIN is stamped on the driver side of the chassis here
Post by twiss » Mon Jul 14, 2014 12:19 pm
Shouldn't be a problem for the MOT though... only if you happen to get pulled over by VOSA
My shell's VIN plate has been missing for a couple of years now lol
Jordanquin
Post by Jordanquin » Mon Jul 14, 2014 12:32 pm
Right ok. Thanks for that everyone. I may get down tonight and have a look but it not it can delay the misery lol. Thanks again guys.
Post by ROBBIE » Mon Jul 14, 2014 1:04 pm
twiss wrote:Shouldn't be a problem for the MOT though... only if you happen to get pulled over by VOSA
Mine failed an not because the vin plate was missing
