Vitara misfire
Hotbob
Re: Vitara misfire
Post by Hotbob » Sun Jul 07, 2013 10:41 am
I mean oil from the camshaft seal. There's o oil in the distributor cap
Hotbob
Re: Vitara misfire
Post by Hotbob » Wed Jul 10, 2013 5:48 pm
Got my head back today.the guy said there is no evidence of anything wrong with the head and crack tested it to 120psi so no cracks in it. Time will tell. Will be re fitting at the weekend
Re: Vitara misfire
Post by turbo-tom » Wed Jul 10, 2013 10:56 pm
Hmm thats strange best luck for re fitting.
Hotbob
Re: Vitara misfire
Post by Hotbob » Sat Jul 13, 2013 4:55 pm
So all refited and it wouldn't start. 5 minutes head scratching and it seems that it had run out of fuel. Strange. Anyway running on 4 at last and did a 40 mile round trip in this heat with no overheating. I do think it feels under powered though. Timing most probably but I have a problem. My timing pullu has 2 slots on it to slot on to the cam shaft. Obviously ones right ones wrong and not noticing this when stripping I'm unsure of knowing for certain if its set up right. Is there a way of knowing other than the timing marks. Thanks Bob
Re: Vitara misfire
Post by ScottieJ » Sat Jul 13, 2013 7:29 pm
Glad to hear its running good with no miss fire now. If its running then you probably have it in the right slot have you set up the timing with a timing light?
If you can get a pic of the cam Pully I can prob tell you if it's in the correct slot. should be able to undo the front cover and pull it open enough to get a pic.
Re: Vitara misfire
Post by Darrell » Sat Jul 13, 2013 8:00 pm
This any help ??
I would be nice if Scott had a shifty at a pic of your setting, as the last thing I want to do is give duff advice if the valves can be hit...
http://www.suzuki-forums.com/suzuki-sid ... e-efi.html
If it's any help we can rob there pics :thumbup:
Re: Vitara misfire
Post by ScottieJ » Sat Jul 13, 2013 8:17 pm
That link pretty much details why I wanted a pic :doublethumbs: so I could see which key way he had it in.
Hotbob
Re: Vitara misfire
Post by Hotbob » Sat Jul 13, 2013 9:12 pm
I'll get a pic tomorrow. The pully bolt needs taking off so you can see one of 2 slots that can be used. No I don't have a timing light I'm afraid
Hotbob
Re: Vitara misfire
Post by Hotbob » Sat Jul 13, 2013 9:21 pm
That link is great thank you. The problem I had was with the key/false key and the 60a. At least I now have something to compare it against. Thanks again
Re: Vitara misfire
Post by ScottieJ » Sat Jul 13, 2013 9:50 pm
You could just have the timing advance slightly out then, this needs to be set up with one ideally as you will loose power if its wrong. so either borrow a mates or pop into a garage and ask them to se it to 10 btdc. should only take 5 mins.
