Starters for sj 1.6 conversion
Cyprus Geoff
Re: Alternative starter for sj 1.6 conversion
Post by Cyprus Geoff » Sat Jan 25, 2014 6:19 am
Any updates Mr Twiss? Mine started playing up last night and nearly failed to start so time for action?
Is it worth trying to DIY refurb?
VMT Geoff
Edit/Update while trying to sort what I need to do to replace my rapidly ailing skinny starter, I came across a thread on difflock that explains (with pics) how to gently grind the block so you can use a fat starter.
http://forum.difflock.com/viewtopic.php ... 22a831c2f6
Hope this helps someone - please feedback any results if you have a go.
Geoff
Cyprus Geoff
Post by Cyprus Geoff » Mon Jan 19, 2015 5:54 pm
UPDATE - I think I have refurbed mine successfully, tomorrow will tell but it sounds way better off the car.
In the meantime, a guy from another forum sent me this info and I wanted to post it here as it may help someone - I can't vouch for the info but here it is anyway:-
Probably too late and I hope you fixed the problem allready, but is an original skinny starter of an automatic gearbox vitara
I got it from EDS in Beilen holland they have them in stock
but i don't know if they send to the UK tho
you could give it a go maybe
Check there website for the phone number
and if you call ask for Rinus
he knows witch one you need Wink
Greetings Bram
Ladaman
Post by Ladaman » Mon Jan 19, 2015 6:27 pm
I've tried to "clean" my starter as the solonoid has been clicking. I managed to get the starter apart. A nice little unit with a speed reduction gearbox built in. But could I open the solenoid? No chance.
I did manage to unfold the seam around the plastic end cap, but I couldn't unsolder the two wire that come out of it. The solder wouldn't melt! Even with a calor gas stove!
Found another on eBay, bought that. Then tidying up the following day, and found a spare :!:
No idea where it has come from :er:
Cyprus Geoff
Post by Cyprus Geoff » Tue Jan 20, 2015 6:39 pm
One thing I forgot to ask, is what vehicle "should" the skinny starter be fitted to?
EDIT:- OK I think it was a Vitara Automatic
Post by twiss » Tue Jan 27, 2015 9:30 pm
My friend had the skinny starter fitted to his japanese sj413... not entirely sure where it came from originally though as they were made in france!
Cyprus Geoff
Post by Cyprus Geoff » Wed Jan 28, 2015 5:02 am
Hi Twiss, well I found a skinny one at a scrappies and it was on a manual SWB Vit and it is a Mitsi one so bang goes my Vit Auto theory!
daemon982
Post by daemon982 » Sat Feb 28, 2015 3:08 pm
I got my skinny starter from a spanish build samurai 1.3 it's a bosch and it fited perfectly on a Suzuki vitara engine.
Gilly_SJ
Re: Starters for sj 1.6 conversion
Post by Gilly_SJ » Wed Mar 30, 2016 1:51 pm
Thread from the dead but seems the most sensible place to put this,
http://www.ebay.co.uk/itm/281474995769? ... EBIDX%3AIT
they say its the slimmer version but the Mitsi Part number doesnt match page one of this thread. Anyone shed some light on this? Its £10 plus postage cheaper than the auto spares place mentioned in the first post thats all!
Beardy89
Post by Beardy89 » Thu Mar 31, 2016 2:05 pm
Just bought this on ebay
What do I need to do to get this to fit my Sammie, with 1.6 Conversion?
http://www.ebay.co.uk/itm/172126308442? ... EBIDX%3AIT
Beardy89
Post by Beardy89 » Thu Mar 31, 2016 8:18 pm
It doesn't fit.
Even after lots of cutting and put an old 9 tooth gear on.
Etc etc the D6RA62 does not fit my Sammie 1.3 gearbox, 1.6 Vit Engine.
