Helens SJ410
Re: Helens SJ410
Post by ScottieJ » Wed Mar 13, 2013 9:37 pm
Tidy! Nice job! Love the little photoshop of the head gasket.
Re: Helens SJ410
Post by dan_2k_uk » Thu Mar 14, 2013 7:24 pm
All sorted :doublethumbs:
Just took it for a test drive and it was a bit hesitant even though I was sure I got the timing back spot on so dizzy must be one tooth out.
Will have to time it up tomorrow when I can get a light of Trotter.
:suzuki:
Re: Helens SJ410
Post by ScottieJ » Thu Mar 14, 2013 11:23 pm
:good: hope you made sure you remembered about the centre oil way on the head gasket and put the gasket up the right way so it's not blocked ;)
Could just need a bit more advance if its running a bit flat, you'll soon find out once the light is on it.
Re: Helens SJ410
Post by dan_2k_uk » Fri Mar 15, 2013 12:30 am
Yeah gasket is all good.
Got timing light it was about 7º out.
Helen took it out for a drive after and said it was worse. Need to investigate in daylight. Probably just summin up with the ignition system.
