muddymessers build thread
Re: muddymessers build thread
Have you been to see the doctor about your bent shaft and purple nuts yet?
- muddymesser
apparently its a grip issue
- muddymesser
finally got my rear tyres on at work today
but i've noticed a problem on the front prop . . . its got a wobble on the splines as the axle has been moved forwards, ive pushed the prop together and it doesnt wobble so ive ordered an 18 mm prop spacer from bits4vits to cure that
but for now i've just removed the prop so MOT man cant say anything
i think its ready for mot on monday
- 10668225_10152642065922719_1445743883_n.jpg (32.67 KiB) Viewed 8163 times
- muddymesser
yay
passes its test today
failed initially on one patch of rust but he repaired it for £30 which i cant argue with
has afew advisory's
1, slight leak on my front hubs
2,slight play in the steering (new rag joint on its way)
3, noisy exhaust
has afew advisory's
3, noisy exhaust
yay, took you long enough
- muddymesser
i know :'( i had money issues
i bought daft stuff for my sj that it didnt really need :/
like purple wheel nuts
- muddymesser
my prop shaft spacer turned up yesterday from bits4vits
got it fitted as soon as i got home
today driving home . . . . my rear prop thew a wobbler on me . . . uj is fudged
- muddymesser
yeah..... erm
i broke it
rear uj went so was driving it frontwheel drive . . . with FWH's off a vitara . . . with plastic internals . . . and i set off fast from work . . . BOOM . . . had to borrow a renault megan to get home :/
i broke it
I guess you now know to not do that again!
- muddymesser
nah . . . i just know to buy better free wheeling hubs before wheel spinning
just found my fixed drive flanges in my tool box so i'll get those cleaned up ready to go back on at some point . . . unless some asin fwh's show up at the right price
