Front Suspension problem!
Ladaman
Re: Front Suspension problem!
Post by Ladaman » Sun Sep 15, 2013 10:53 pm
All part of the :suzuki: learning curve.
TomBod08
Post by TomBod08 » Sun Sep 15, 2013 10:53 pm
ScottieJ wrote:Yeah fit the spacers and report back, if you still get shackle inversion it's time for a slightly longer shackle, looking at the shackle angle at ride height I have a feeling you might need them even with the spacers.
How do you fit them? 2 of them have holes in and the other 2 don't, do I need to weld them on?
One life. Live it....With a Suzuki
Post by Jordi » Sun Sep 15, 2013 10:57 pm
Photo of them please.
Post by dan_2k_uk » Sun Sep 15, 2013 10:57 pm
The ones with the holes in will be for the front. Get those fitted as thats where the problem is.
I still think they will be trying to invert the shackles even with the bump stop spacers fitted.
Worth fitting them to avoid any damage though.
Dont know how the rears would fit as a bolt on item as there's no original holes to use.
Post by Jordi » Sun Sep 15, 2013 10:59 pm
Rears are probably weld on. I just welded all of mine on. I was being lazy.
Ladaman
Post by Ladaman » Sun Sep 15, 2013 11:01 pm
TomBod08 wrote:How do you fit them? 2 of them have holes in and the other 2 don't, do I need to weld them on?
Doesn't it say in the instructions?
Ring MGP for advice.
TomBod08
Post by TomBod08 » Sun Sep 15, 2013 11:10 pm
Just had a look now, looks like I do have to weld on the rear, only problem now is I don't have a welder :x
Post by Tramp » Sun Sep 15, 2013 11:13 pm
Drill the rear mounts like the front (i wanted to tap them too) well, I was going to......... But never got around to it
Post by Jordi » Sun Sep 15, 2013 11:16 pm
Fronts should have a set of longer bolts with them.
Soak the fronts on your SJ with a good amout of WD40 over night as i always shear the bolt when i undo them.
TomBod08
Post by TomBod08 » Sun Sep 15, 2013 11:18 pm
Yeah never thought of that, would there be room on the chassis to drill holes too? For some strange reason the bump stops are in different places front and rear :lol:
