Page 8 of 10
Re: Front Suspension problem!
Posted: Sun Sep 15, 2013 10:53 pm
by Ladaman
All part of the
learning curve.
by TomBod08
ScottieJ wrote:Yeah fit the spacers and report back, if you still get shackle inversion it's time for a slightly longer shackle, looking at the shackle angle at ride height I have a feeling you might need them even with the spacers.
How do you fit them? 2 of them have holes in and the other 2 don't, do I need to weld them on?
Posted: Sun Sep 15, 2013 10:57 pm
Photo of them please.
by dan_2k_uk
TomBod08 wrote:ScottieJ wrote:Yeah fit the spacers and report back, if you still get shackle inversion it's time for a slightly longer shackle, looking at the shackle angle at ride height I have a feeling you might need them even with the spacers.
The ones with the holes in will be for the front. Get those fitted as thats where the problem is.
I still think they will be trying to invert the shackles even with the bump stop spacers fitted.
Worth fitting them to avoid any damage though.
Dont know how the rears would fit as a bolt on item as there's no original holes to use.
Posted: Sun Sep 15, 2013 10:59 pm
Rears are probably weld on. I just welded all of mine on. I was being lazy.
Posted: Sun Sep 15, 2013 11:01 pm
by Ladaman
TomBod08 wrote:How do you fit them? 2 of them have holes in and the other 2 don't, do I need to weld them on?
Doesn't it say in the instructions?
Ring MGP for advice.
Posted: Sun Sep 15, 2013 11:10 pm
by TomBod08
Just had a look now, looks like I do have to weld on the rear, only problem now is I don't have a welder
Posted: Sun Sep 15, 2013 11:13 pm
by Tramp
Drill the rear mounts like the front (i wanted to tap them too) well, I was going to......... But never got around to it
Posted: Sun Sep 15, 2013 11:16 pm
Fronts should have a set of longer bolts with them.
Soak the fronts on your SJ with a good amout of WD40 over night as i always shear the bolt when i undo them.
Posted: Sun Sep 15, 2013 11:18 pm
by TomBod08
Yeah never thought of that, would there be room on the chassis to drill holes too? For some strange reason the bump stops are in different places front and rear
