Page 10 of 10
Re: Front Suspension problem!
Posted: Sun Sep 15, 2013 11:37 pm
by Darrell
It does mean under articulation as the spring flattens the axles will move further forward.
I get ya
Posted: Sun Sep 15, 2013 11:38 pm
by TomBod08
One more thing! My sump is leaking oil, think I need a washer for it. Has anyone else had problems with it?
by TomBod08
Ladaman wrote:I'm only in Huddersfield. I can help if you want.
What part of Huddersfield do you live in?
Posted: Sun Sep 15, 2013 11:39 pm
Might just need nipping up. Failing that when you do an oil change next just take the sump plug and washed to any motor factors. They usually have a load of various sizes you can match it too.
Posted: Sun Sep 15, 2013 11:40 pm
by TomBod08
Dammit! Just changed the oil as well, then about a week after I noticed the leak
Posted: Sun Sep 15, 2013 11:44 pm
by Darrell
You can undo it a little and then wrap some PTFE tape around it and tighten it back up.
That's what I did last time I changed the transfer box oil and it leaked a little.
Posted: Sun Sep 15, 2013 11:45 pm
by TomBod08
Did it work? I would imagine it still seeping through and eroding over time.
Posted: Sun Sep 15, 2013 11:47 pm
by Ladaman
TomBod08 wrote:Ladaman wrote:I'm only in Huddersfield. I can help if you want.
PM Sent.
Posted: Mon Sep 16, 2013 12:08 am
by Darrell
TomBod08 wrote:Did it work? I would imagine it still seeping through and eroding over time.
Worked fine, been like it for years
But it doesn't get anywhere near as hot as an engine, but ptfe is rated to "260 degree C" continuous use
And next time your get probably get a new washer.
I just wrapped it around a few threads, more like string than tape, if you get what I mean.
Posted: Mon Sep 16, 2013 12:13 am
by TomBod08
Will give that a try then, definitely a cheap option cheers
