Sj410-1.6 8v efi conversion
Posted: Thu Apr 17, 2014 6:22 pm
by Dougie13
I am abs desperate to get my zuk back on the road, I have bought a 1.6 8v efi engine, 1.3 clutch gearbox flywheel adaptor plate etc etc have the 1.3 starter and 1.6 alt... I am a little stumped with the efi tho, I wasn't even aware that the 8v had efi thought it was only the 16v, I went with the 8v thinking it would be much easier to fit, basically I'm looking for advice in what is best, keep the efi or change to carb, I have no wiring knowledge ... Any help would be greatly appreciated!!! Cheers
Re: Sj410-1.6 8v efi conversion
Posted: Thu Apr 17, 2014 6:37 pm
hi there is some info about how to wire the injection 8v up but im not sure where it is...
what carb did you have on your 1.3? if it was an SU or a webber then it would be easiest to put the manifold and carb straight onto your 1.6 as it should fit
i dont think the standard carb from the 1.3 will work on the 1.6 though... probably not very well
if you did go carb you would need an electric fuel pump
Im sure someone will be along with the wiring info soon
Posted: Thu Apr 17, 2014 6:56 pm
by Dougie13
It's actually a stock 410 I'm running , it's my every day car not just an off Roader , so in terms of fuel economy etc it the efi not better?
Posted: Thu Apr 17, 2014 6:58 pm
by Dougie13
Ideally a step by step guide of what's needed to get the 8v running with efi is what I want provided it's not going to cost me hundreds more than converting to carb
Posted: Thu Apr 17, 2014 7:01 pm
by Ladaman
Keep the EFI.
It might be a little bit of an issue to get working, but it will be worth it.
A great improvement over a carb, especially off road.
Posted: Thu Apr 17, 2014 7:08 pm
by Dougie13
Ok well how exactly do I keep the efi, from what I have read the efi would deff suit me better
Posted: Thu Apr 17, 2014 9:29 pm
by Rhinoman
if you did go carb you would need an electric fuel pump)
It won't work too well on the EFI head because there is no provision for it - it would have to be an aftermarket pump.
Have you got any idea what year the engine is from? have you got any of the EFI parts?
Posted: Thu Apr 17, 2014 9:39 pm
Yes... thus the electric fuel pump...
