Grand vitara transfer box problems
Posted: Fri Sep 05, 2014 8:38 pm
Hello
I'm new here but i'll probably end up posting alot of questions.
I have a 2002 GV 2.0td that I managed to slide backwards into a wall at ~50mph.
Broke the steering column and rack and buckled a back wheel.
Most of that is sorted now but the drive train must have taken a fierce knock.
Immediately after the crash the car was somehow in 4wd, I managed to put it back into 2wd no problem.
When the steering was sorted I went to pick it up and I could change between 2H and 4H no bother but couldnt get the transfer into 4L or N.
I had a play with it the other night and took out the transfer lever since I'd heard about them getting knocked out of line. I tried to shift the box into low range with a screwdriver by rotating the right hand selector shaft and pushing it back. It rotates fine but wont push back, the left hand shaft ( for 2H and 4H) moves fine, yet somehow its now stuck in 4H after all my fiddling.
Sorry for the lenghty explanation, I've been as concise as I can!
I cant see any other damage on the outside of the box or anywhere else along the drive train (apart from the buckled wheel)
Any suggestions greatly appreciated. Could it just be wind-up? It may have been in 4H when it was winched onto the back of the recovery truck.
Cheers!
Cheers!
