Bigger shackles
Josh-holden
Bigger shackles
Post by Josh-holden » Mon Nov 10, 2014 11:02 pm
What are the pros and cons to bigger shackles? Would going 3/4" make to much stress on components?
Re: Bigger shackles
Post by dan_2k_uk » Mon Nov 10, 2014 11:30 pm
The shittest possible mod for standard SJ suspension. End of....
Re: Bigger shackles
Post by dan_2k_uk » Mon Nov 10, 2014 11:31 pm
Ruin castor angle.
Ruin approach/departure angle.
Ruin drive line angles.
Ruin springs.
Re: Bigger shackles
Post by Darrell » Mon Nov 10, 2014 11:41 pm
I don't think Dan likes this idea :D
Re: Bigger shackles
Post by ScottieJ » Tue Nov 11, 2014 12:18 am
The longest shackles I would ever suggest running on stock springs would be 100mm between centres, stock are 70mm. This won't effect your caster angle or approach angle enough to cause any issues.
Re: Bigger shackles
Post by twiss » Tue Nov 11, 2014 9:08 am
I've got 100mm shackles on the front with lift springs, and they are OK
Then +3" lift shackles on the back, which are utter crap!
Depends how you use them, but not just as a cheap form of lift
Josh-holden
Re: Bigger shackles
Post by Josh-holden » Tue Nov 11, 2014 1:43 pm
All im after is to lift the transfer box up a bit
Re: Bigger shackles
Post by ScottieJ » Tue Nov 11, 2014 3:37 pm
You can lift the transferbox without touching the suspension. might even get away with lifting it around .5-.75" with no modifications to the body.
when you lift it 2" so it's above the bottom of the chassis rails you need to tweak the transmission tunnel. (these aren't my pics)
Ladaman
Re: Bigger shackles
Post by Ladaman » Tue Nov 11, 2014 3:50 pm
Or fit a rock bucket and don't worry.
Re: Bigger shackles
Post by ScottieJ » Tue Nov 11, 2014 4:01 pm
I prefer the extra clearance, it does make quite a difference not having a Tcase hanging down to catch on things.
I do have a guard as well though so I just slide over stuff
