Page 1 of 3
G box to Pug 1.9TD enigne?
Posted: Mon Dec 15, 2014 8:27 pm
by waynesworld
Can we have a list please of RWD gear boxs that will mate up with the Pug 1.9TD engines, not using an adaptor plate, all but the LDV Pilot G box as the gearing is no good, been there and done that.
cheers all
wolly
Very Happy
Re: G box to Pug 1.9TD enigne?
Posted: Tue Dec 16, 2014 7:16 pm
by Anton
I'd look into diesel vitaras. Not grand vitaras - but original vits - I'm fairly sure they had pug 1.9 NA's out of the factory, so they should mate up. Built in t-case too, should simplify your dutton build.
Posted: Tue Dec 16, 2014 7:18 pm
Not hard to convert to run an SJ Tbox either.
Posted: Tue Dec 16, 2014 9:01 pm
by d_r_1989
The commercial vitara had the xud engine so a commercial gearbox will fit and have a longer ratio but they run 4.8 diffs so could be quite long with a 3.74 or 3.94 diff.
Posted: Tue Dec 16, 2014 11:17 pm
by Anton
The Vit diffs are geared to their tcase being 1:1 high. Samurai tcases are 1:1.4(ish) and 410 cases are 1:1.6(ish).
http://forum.suzukiclubuk.co.uk/vi ... =12&t=2947
Mixing and matching parts, you may find that you can get a range that suits your needs.
If the Vit commercials have odd ratios, look into getting a Vit gearbox and a Vitara diesel bellhousing as I believe they separate - you may find you can swap the bellhousing onto another gearbox that suits you more.
Posted: Wed Dec 17, 2014 8:42 pm
by d_r_1989
Vitara gbox and bell housings separate very easily, but they are pricey as people want the bell housings.
Posted: Wed Dec 17, 2014 8:58 pm
by Anton
You may have to consider making an adapter plate or modifying a bellhousing then...
Posted: Wed Dec 17, 2014 9:07 pm
by d_r_1989
My gbox is a samurai box with modified bell housing and works well.
Posted: Sat Jan 03, 2015 1:01 pm
by waynesworld
Hi Daryl, that was you then on that other slooooow forum lol.
Be interesting to see how your is converted then mate, and how it drives on road. If i can i will pop up when you change your clutch, when you planning it mate. In no rush as getting bits together and lots to to on another kit car yet. weather is holding me back now.
Posted: Sat Jan 03, 2015 1:14 pm
by Anton
d_r_1989 wrote:My gbox is a samurai box with modified bell housing and works well.
Just out of interest, got a build thread or pics of the bellhousing mods?
I'm interested in how it was done, what clutch you used etc.
