Hi all.
My indicators and hazards stopped working today and I'm having trouble finding/identifying the relay/flasher. None of the indicator lights work and there is no clicking from the relay.
One garage I went to managed to find a relay and pulled it out. Assuming that it is the correct one I've been trying (without success) to buy one locally but now I'm wondering if this is the correct one or whether it is the fuel pump relay.
The photos are of the one that was taken out.
Any help appreciated.
Eric
Help please, with indicator/hazards
- 20151006_174615B.jpg (36.02 KiB) Viewed 3347 times
- 20151006_174604B.jpg (28.52 KiB) Viewed 3347 times
______________________________
Keep on keeping on -- with a Zook!
Due to the current economic climate, the light at the end of the tunnel has been switch off.
Re: Help please, with indicator/hazards
It has the part number for the main relay or the fuel pump relay, the indicator relay should be in the same area.
Thanks Rhinoman. Found it
. I thought it was that bit right at the start but changed my mind because it seemed to be permanently fixed to the metal bracket. Sussed out that it slides off.
