Soft top clips - Where to buy? [see pics]
Phillips321
Post by Phillips321 » Tue Apr 26, 2016 5:18 pm
Hi guys,
I need 3 of the popper type clips:
and 1 of the pin type clips:
Any idea where i can get them from?
Many thanks
SherwoodNash
Re: Soft top clips - Where to buy? [see pics]
Post by SherwoodNash » Tue Apr 26, 2016 5:30 pm
zook123
Post by zook123 » Tue Apr 26, 2016 5:42 pm
Wow! The ones for my Jimny are nearly £8 each!!!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Post by donkeychomp » Tue Apr 26, 2016 8:20 pm
Camping shops sell them and you'll need a tool if you want to put new ones on your soft top. ThinkI got 100 and the tool for a fiver.
Phillips321
Post by Phillips321 » Wed Apr 27, 2016 11:06 am
Thanks, have just ordered a set.
Post by twiss » Mon May 02, 2016 8:02 am
They look better than the last ones I used.... they were rivet on type and came off eventually
Phillips321
Post by Phillips321 » Tue May 03, 2016 7:52 am
twiss wrote:They look better than the last ones I used.... they were rivet on type and came off eventually
However the right most lug on the tailgate is going to be a pain. The thread has snapped off in the hole which i can't get to the back of. I'm planning to drill it out and see if i can put the new one in there.
SherwoodNash
Post by SherwoodNash » Tue May 03, 2016 8:25 am
These Easy Out 3-25mm Bergen 2584 sets are mighty useful for working on your SJ.
Phillips321
Post by Phillips321 » Tue May 03, 2016 8:41 am
SherwoodNash wrote: Image
I've not seen them before, how do they work? You drill the old thread and then use the other bit to make new thread?
Post by ROBBIE » Tue May 03, 2016 9:00 am
They are for removing snapped bolts, drill down the middle of bolt and screw one in and hopefully will turn the bolt out. You will need to drill and re tap the thread in the door
